Trivtush
Feb 21, 2020Follower
RBR50-can’t disable Armor
Cannot disable the Armor. When you toggle the switch in the app, it does not turn the security off.
Christian_R
Feb 25, 2020NETGEAR Employee Retired
Hello Trivtush - May you provide us with a screenshot of the app when tapping on the toggle.
Thanks,
Christian
Ngearvictim
May 27, 2020Guide
I don't see a toggle or any way to disable on my Orbi app, or in my Orbi router administration pages.
please help.
Christian_R wrote:Hello Trivtush - May you provide us with a screenshot of the app when tapping on the toggle.
Thanks,
Christian
- Christian_RMay 29, 2020NETGEAR Employee Retired
Hi Ngearvictim,
Please refer to the article below to disable Armor using the Orbi app. You may need to update to the latest version of the Orbi app which can be done by reinstalling the app.
Christian
- kim1of2Sep 24, 2020Aspirant
I'm having the same problem since updating firmware that came with the Armor security. Internet is constantly dropping random devices: Ring, iphones, Smart tv, just randomly. I never had this problem prior to the firmware update with Armor trial. When I enter Security snd attempt toggle off a message pops up stating "Error Device is offline". The device is not offline, as I am actively logged in through the app. On a related forum there was a suggestion to enter "Remote Access" and turn this on and off. There is no "Remote Access" category in the Nighthawk app. I assume this means the "Anywhere Access" category. However when I attemppt to toggle "Enable Access Anywhere" I get yet another Error messsage. This one reads "Some error occurred while enabling/ disabling Anywhere Access."
Is there any other way to remove the Armor trial? Working remotely and having a child in Virtual school makes this problem especially frustrating, as we are both being dropped off the wifi repeateedly throughout the day.
Second error screenshot below
