Trivtush
Feb 21, 2020Follower
RBR50-can’t disable Armor
Cannot disable the Armor. When you toggle the switch in the app, it does not turn the security off.
Christian_R
Feb 25, 2020NETGEAR Employee Retired
Hello Trivtush - May you provide us with a screenshot of the app when tapping on the toggle.
Thanks,
Christian
Mewho411
Nov 26, 2020Aspirant
I have tried to figure out how to disable Armor, I can't find it. I have the RB50 router and satellites. i connect directly to the app and in it, I click on security <nothing happens> I try to click on advance/security and can't find a disable for Armor.
I have searched other links within netgear - nothing.
And I find a disable via the mobile app either. I did take pictures but sadly every time I upload <chrome or edge> the process locks up and becomes unresponsive. I don't want Armor it's frankly not worth it. I thought it would protect the router from being DDoS attacked with an ips/ids so that my system won't keep faulting but that's not it's purpose and I already am protected on my devices from spam/antiv/maleware.
help please.
