brise
May 13, 2019Aspirant
RBR50 High Risk Vulnerability
Netgear Armor (free trial) has completed a vulnerability assessment on my network and has identified a High Risk vulnerability on the RBR50 router itself. The description is "Basic auth found". Can s...
brise
Thanks for the response. I looked at the links you provided and I don't see that the RBR50 was involved. In any case:
1 - I had already set the password recovery option (as recommended) on the router.
2 - It turns out that the Armor vulnerability alert showing is on each of the 2 RBS50 *satellites* (not the router). The date shown is yesterday - May 12. No other information is shown on the alert.
3 - I am able to log in to the router and satellites individually using my admin user/pwd. I didn't expect to be able to log into a satellite - but there are no configuration options there anyway.
Is this alert something I need to worry about? I guess the satellite access login is available only if already on my network.
Orbi-Roc
May 13, 2019Luminary
Hi again brise . I know the Orbi routers weren't part of this Netgear Security Alert. I was merely trying to point out that the issue reported in your vulnerability assessment scan is a known issue to Netgear with other routers; and since their own Netgear Armor reported it in the context of a vulnerability scan, then I assume that the Orbi routes also suffer from the same security flaw. I am no expert at this brise , far from it. I basically have the same Orbi set up you have and it makes me nervous that vulneraribility assessment scans are not being performed on a regular basis; even more so after reading your post.
