Diverjimbo
Nov 17, 2023Aspirant
RBR860 Allowable Website
My question is where do I check in my router to determine whether it is blocking access to a specific website. Or, is there a place in the RBR860 where I can enter a website such as http://blahblahb...
- Nov 17, 2023
Are Bitdefender Armor or Smart Parental Controls (SPC) enabled on this system?
Diverjimbo
I did search through similar posts very close to the same issues I am having. The website I am trying to access is IPTV. I see others with the same issue of being blocked from accessing that site. I find many suggestions from some very knowledgeable folks on here about things to check and do, but do not find where the problem was actually identified and resolved.
Hopefully, one of you who experienced this same problem sees my post and will let me know what they did to resolve their issue.
Again, TIA
Jim
CrimpOn
Nov 17, 2023Guru - Experienced User
- DiverjimboNov 30, 2023Aspirant
Don't know how I didn't realize I had to go to Netgear Mobile App to turn off Bit Defender/Armor security.
Once I turned it off, I was immediately able to access IPTV.
Thanks for the idea.
Jim
