CMoneyTrading
Jul 12, 2024Aspirant
RBRE960 - Armor blocks access to Walmart and Discord app (July 2024)
Recently, after I noticed the Armor app went from being branded as Bitdefender to Netgear Armor, access to the Walmart app and Discord app is blocked when using the Orbi Wifi. If I turn Armor off or ...
CMoneyTrading
Jul 10, 2024Aspirant
Recently any phone that uses the Orbi Wifi cannot connect to the Walmart app. Walmart.com is fine, but the app will not connect. If we go off the Wifi and to mobile data, works again.
Tried to reboot, power cycle but no luck.
How do I clear out whatever the issue is so we can use the Walmart app on the wifi again?
thanks
Jul 10, 2024Guru - Experienced User
Something to ask Walmart about there app.
- CMoneyTradingJul 10, 2024Aspirant
Like I said, the app works fine on mobile data or other Wifi connections.
It's clearly an issue with my Orbi.
- FURRYe38Jul 10, 2024Guru - Experienced User
Is Armor or SPC enabled on the system?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageWhat Firmware version is currently loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- CMoneyTradingJul 11, 2024Aspirant
Is Armor or SPC enabled on the system? Armor is enabled on the devices and the router itself.
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...'While at home' meaning we now have to turn this on/off at home and then back on when leaving home? If that is a real solution, that's terrible. Noone is going to do that.
V7.2.6.31_5.0.24
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Netgear CM2000
