CMoneyTrading
Jul 12, 2024Aspirant
RBRE960 - Armor blocks access to Walmart and Discord app (July 2024)
Recently, after I noticed the Armor app went from being branded as Bitdefender to Netgear Armor, access to the Walmart app and Discord app is blocked when using the Orbi Wifi. If I turn Armor off or ...
Jul 10, 2024Guru - Experienced User
Something to ask Walmart about there app.
CMoneyTrading
Jul 10, 2024Aspirant
Like I said, the app works fine on mobile data or other Wifi connections.
It's clearly an issue with my Orbi.
- FURRYe38Jul 10, 2024Guru - Experienced User
Is Armor or SPC enabled on the system?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageWhat Firmware version is currently loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- CMoneyTradingJul 11, 2024Aspirant
Is Armor or SPC enabled on the system? Armor is enabled on the devices and the router itself.
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...'While at home' meaning we now have to turn this on/off at home and then back on when leaving home? If that is a real solution, that's terrible. Noone is going to do that.
V7.2.6.31_5.0.24
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Netgear CM2000
