fathobbit
Apr 16, 2019Star
2.3.1.44 update preventing connection to xfinity account
I do not have Armor activated but after this update to the new verion I'm not able to connect to Xfinity website using my desktop (ethernet) or from my phone (wifi). If I disconnect my wifi from pho...
DexterJB
Apr 17, 2019NETGEAR Moderator
Hi fathobbit,
Welcome to the community!
Are you saying that you're able to access the website on your phone when using mobile data? Are you getting an error message when trying to access the website? If possible, a screenshot would help out a lot.
Dexter
fathobbit
Apr 17, 2019Star
Hi Dexter,
I had also opened a support case on the same issue yesterday. This morning on my phone and desktop, I was able to access xfinity. I did not change anything at all.
On the actual error message that you were asking, there was really none, on the phone it will just keep trying to connect, the three dots keep running. On the desktop it just used to come up with an error page that its was taking too long to connect.
Is there anyway to disable to auto update on the orbi so that these kinds of things doesn't surprise us.
Thanks
Prem.
