John_Ba
May 12, 2024Luminary
Armer not linking between devices and new router
I replaced an old Orbi with a newer one and transfered my remaining armor sub over OK. But on the Orbi app it tells me my phones need armor installed But it's already is installed On a desktop it's ...
John_Ba
May 15, 2024Luminary
They canceled a sub and transfered the outstanding sub to the bew Orbi It turns out there is no way customers can do either and even can't if you have a current sub on the router you want the outstanding time moved to
But only they can do either just needed a little nudge to move it past the the otiginsl nothing we can do to we can sort it all.
John_Ba
Bit it turns out you end up having to un and reinstall armor if it's to br linked to the new Orbi
Not marvellous system
- John_BaJun 28, 2024Luminary
The biggest problem I have found changing Orbi is the new one RBR850 didn’t take over the installed security programs on PCs or androids. I had to uninstall the existing programs and reinstall from a new link. But even then I have one android listed under the old RBR50 that I did this for and isn’t on the list for the RBR850 devises. To add to the frustration devices of visitor’s are still being added under the old Orbi. Basically it’s a mess as Netgear have either not thought this change of devices through or not bothered to program for it properly.
Looking at the lists even reinstalling hasn't added most devices to the new Orbi and most are still added to the old one. I just uninstalled and reinstalled on the PCI am using. I sent the link to the "unprotected device" from the RBR850 list and its still shown under the old Orbi and as unprotected (as sub has expired) but also under the new RBR850 shown as unprotected as well. Its basicly a real mess if you change routers
I have contaxted support but I don't have high hopes of them having any idea how to sort out changing one router for a new one with Armor.
But I have now realized even that doesn't work most of the time as reinstalls have been re-added to the old router not new. Its basically a total mess when you change routers.
