Wxman38
Dec 06, 2022Guide
Armor support
I tried to talk to someone in support about the problems their Armor program is causing some sites to not be able to connect without having to reboot the router. Unfortunately, every time I reached ...
- Dec 06, 2022
Again, armor is baked into the firmware. But if something didn't get disabled properly when you turned it off, it can help.
Dec 06, 2022Guru - Experienced User
Try the factory reset and just make sure not to setup armor or the free trial.
Alcatel is a brand, not a model. Check out the label on it
Wxman38
Dec 06, 2022Guide
This is all the info on the ONT ALCLF3AFDBOB PN 3FE51880AA. When I initially installed the router, I set it up manually not via the Nighthawk app. There was a popup for Armor, but I didn't activate it. I changed my two dns servers to ones from Cisco. Basically, I left all of my setup the same as I had on my RAX75 router.
With the RAXE290, I've had no problem getting to the internet. It has given me problems using iTunes, Macrium Reflect, occasionally Windows Update, and it won't let me go to www.tvtango.com.
- Wxman38Dec 03, 2022Guide
Apparently there is a problem with Armor not giving some programs enough time to connect with a site on the internet. Having using both Edge and Firefox Armor fails to connect with the site www.tvtango.com.
Here's the response when the connection fails:
The connection to the server was reset while the page was loading.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the web.The only fix for this is to reboot the router RAXE290. After you reboot it, there is no problem connecting to tvtango.com. However, after a short period of time possibly less than an hour you get the same message as above. When you actually use the browser it shows the site and it uses www.google.com to search for it.
So how do I fix this without constantly having to reboot the router??
- plemansDec 06, 2022Guru - Experienced User
do you have ipv6 enabled?
Also, are you using icloud relay or private mac/ip address ?
- Wxman38Dec 06, 2022Guide
I have ipv6 enabled. I'm using a Dell XPS 8930 with Windows 11.
I have ipv6 enabled. I don't have an iCloud relay. I'm using DHCP as far as ip address. I just had to reboot the router to get Windows Update working again. It was giving the error that you have no internet connection. This is the same problem I get with iTunes. These programs indicate no internet connection despite the fact that I do still have an internet connection.
I would try the factory reset
Do you think that would get rid of Armor?
- Wxman38Dec 07, 2022Guide
Tried the factory reset today. First thing I noticed from yesterday was the Nighthawk app kept indicating no internet connection.
After the factory reset, I ended up seeing the Nighthawk app when I tried to set up to my settings. It doesn't give you a choice about Armor. In order to proceed, you have to accept it. However, after the reset, I restored my cfg file, and was back in business.
Now when I look at the Nighthawk app on my phone it shows I have an internet connection. It also shows Armor enabled and activated.
At the moment iTunes and the other software problems seemed to have stopped. However, since they used to come back after a few hours I won't know if the reset did the trick. Hopefully the reset worked. Thanks.
- Wxman38Dec 16, 2022Guide
Actually, I was still having the problem after this. Yesterday I talked to the tiger team at Netgear. Found out the solution that allowed me to go to iTunes, tvtango, etc. Logged into my RAXE290 from my browser. Selected the Advanced tab and on the left side menu opened the Security section. In Security I selected Block Sites and changed the selection from Always to Never and then applied the change. Now everything works like it should.
