goddss6
May 28, 2019Follower
How do I disable/delete Netgear Armour
I accepted the trial of Netgear Armour and have been trying for a month to turn this crap off. I do not want it. It says that I have 45 days left... My phone dings that there is security threat eve...
VaqueroPhotogra
Jan 06, 2021Initiate
I was so aggravated when Armor activated only because I did a soft reset to the router. I was frustrated and did not want it in the first place.
Steps to get rid of this ridiculous Armor was tuff enough I searched my answer out.
Using the NetGear Nighthawk app open it.
Then in the upper left corner of the app there is a little house icon, click to open that
Next select Settings
Next select Security
Next slide the slider to off for Armor
Your are all done
horustx
Jan 07, 2021Guide
I was able to disable it from my phone app, but it doesn't seem there is an option to do it from the router web page.
My router is new (bought it yesterday).
Armor got activated without my consent - I just got an email welcoming me.
If it comes back or causes me any issues, I will not do any factory resets. If it (Armor) ever interrupts my work and/or cause me financial damage, Netgear won't be happy.
