Gary_A
Jun 01, 2019Guide
Is Armor activated or not?
Armor.netgear.com website shows I have a subscription. The IOS App shows the tile for Armor as expired, clicking it takes me to a screen to renew my subscription, clicking to renew takes me to the A...
Santap
Jun 02, 2019Tutor
Exactly same issue for me as well.
Router: Orbi RBR50
Firmware: 2.3.1.60
- Gary_AJun 03, 2019Guide
I called support at Bitdefender and they have escalated it to a level 2 as the tech could not figure out the reason the the orbi app or router is not seeing that Armor is activated. Great tech, understood the problem but just couldn't fix it. Netgear really needs to take some ownership in this but knowing that they only provide 90 days of support via phone or e-mail after pruchase means I don't want to call and be told I have to pay for the call. I will update this thread once I see what Bitdefender does.
- Gary_AJun 04, 2019Guide
Bitfender resolved my issue and Armor shows actived in the app and router now. I recommend contacting them at https://www.bitdefender.com/consumer/support/
- Christian_RJun 24, 2019NETGEAR Employee Retired
Hello Santap,
We have also noticed an issue. If you believe that your expiration date on the status is not accurate, please DM me with your serial number/email address and we will look into it for you.
Gary_A - Glad to hear you were able to get it resolved. Also, thanks for posting an update on the thread as it may help others who may experience the same issue.
~Christian
