megavolt17
Jul 24, 2024Star
Re: NetGear Armor for Windows 11
For me I am using Windows 11 with an ARM processor. When I had an Intel based computer I could install Armor, which would install and register Bitdefender. Armor Bitdefender downloaded from my Or...
megavolt17
Sep 06, 2024Star
My setup is MacBook Pro M3, which is ARM based. Windows 11 ARM runs fine, and Bitdefender (from their site) runs fine. Netgear Armor doesn't do anything at all when the installer is run. Pretty pathetic not to support ARM processors since they have been supported by Windows for over 3 years already!
Sep 06, 2024Guru - Experienced User
Something to make contact with NG support about and ask:
- KM82Sep 06, 2024Initiate
I contacted support for the Armor subscription but they couldn't find a solution despite going through several different options. I do have an open support ticket now though, so we'll see if they address this issue. I have my doubts.
- megavolt17Aug 14, 2024Star
If your custom PC has an ARM processor then it seems to be a reported issue. The Netgear Armor installer does not work with the PC like Microsoft Surface Pro, M series Macs running Parallels, etc. It seems to only install with Intel and AMD type CPUs.
Bitdefender itself will install and run fine from their web site, but Bitdefender installed this way won't use your Armor subscription. I tried Netgear customer support twice but they were not able to assist, and suggested I contact Bitdefender. Bitdefender said the Armor installer was 4 years old and that they had no control over the Netgear installer.
So glad my Armor subscription just auto-renewed for another year!
- megavolt17Sep 16, 2024Star
Is the computer you can't install Armor on perhaps using an ARM processor? It seems that on computers like Microsoft Surface Pro, M series MacBooks, HP EliteBook Ultra, HP OmniBook X, etc. that the Armor app runs but never installs Bitdefender. There seems to be no workaround to this problem.
I tried dealing with Netgear (who told me it's a Bitdefender problem and to contact them). I contacted Bitdefender who pointed out that their own Bitdefender installer work fine, and that they have no control over the Armor installer. Catch 22.
