megavolt17
Jul 24, 2024Star
Re: NetGear Armor for Windows 11
For me I am using Windows 11 with an ARM processor. When I had an Intel based computer I could install Armor, which would install and register Bitdefender. Armor Bitdefender downloaded from my Or...
Bitmask64
Dec 05, 2024Aspirant
I am experincing this same issue on the Surface Pro 11 with the Snapdragon CPU
- megavolt17Dec 05, 2024Star
It seems that Netgear has completely forgotten anyone using an ARM chip. What is funny is if you subscribe to Bitdefender instead of Armor (which is Netgear's Armor version of it) everything works. Bitdefender said Armor uses an obsolete 32 bit installer, and that Netgear had to update that before it would work properly.
