megavolt17
Jul 24, 2024Star
Re: NetGear Armor for Windows 11
For me I am using Windows 11 with an ARM processor. When I had an Intel based computer I could install Armor, which would install and register Bitdefender. Armor Bitdefender downloaded from my Or...
megavolt17
Jan 05, 2025Star
Nope. I just tried installing Netgear Armor/Bitdefender and it still does not work for me. It is frustrating that Bitdefender supports ARM based PC and has for a few years buy Netgear can't/won't update their custom installer so that it works. You would think that updating Bitdefender would be the harder part.
I imagine they could pay Bitdefender to help them with their installer if they can't do it in house.
JB_04
Jan 05, 2025Tutor
Exactly well they have till April to fix it or they will be losing a paying customer but I guess they don't care. It installed just fine on one of my computers that does not have a arm processor but does have windows 11. It's only the surface pro 11 with arm that has the issue. Seems like a easy fix for them with it only being the installer but I'm sure it has something to do with money between bit defender and Netgear but who knows. I'll be gone in April if they can't figure it out. I won't be going to bit defender either. I'll leave them both. I continue to use my Norton 360. Everyone that is having this issue Norton 360 does work with Arm based computers so leave them both and go for Norton since they can't play nice with each other.
