megavolt17
Jul 24, 2024Star
Re: NetGear Armor for Windows 11
For me I am using Windows 11 with an ARM processor. When I had an Intel based computer I could install Armor, which would install and register Bitdefender. Armor Bitdefender downloaded from my Or...
JB_04
Jan 05, 2025Tutor
Exactly well they have till April to fix it or they will be losing a paying customer but I guess they don't care. It installed just fine on one of my computers that does not have a arm processor but does have windows 11. It's only the surface pro 11 with arm that has the issue. Seems like a easy fix for them with it only being the installer but I'm sure it has something to do with money between bit defender and Netgear but who knows. I'll be gone in April if they can't figure it out. I won't be going to bit defender either. I'll leave them both. I continue to use my Norton 360. Everyone that is having this issue Norton 360 does work with Arm based computers so leave them both and go for Norton since they can't play nice with each other.
megavolt17
Jan 05, 2025Star
Mine expires in August. I have used Norton in the past which worked on my M3 MacBook, my Windows 11 ARM (Parallels Apple MacBook M3), iPhone and iPad. Bitdefender works as well and is often cheaper than Netgear's Armor (it's frequently on sale if you look for it). Norton customer service is realtime, Bitdefender can take weeks or months to hear back from a real person if your support issue is more than basic.
Spectrum (my Internet provider) offers F-Secure antivirus and firewall for free. I will research that to see how good it is. I bet your ISP offers something similar.
The only thing we would lose would be the Armor router protection. There are router viruses, but there is so little information about what Armor actually does for the router that I am unsure what good it is. I have never gotten a message that the Armor on the router did anything to block malware, IOT attacks, etc.
- darkwing81Jan 20, 2025AspirantHas anyone received an update as to whether or not Netgear plans on updating the software for Windows Arm machines?
- megavolt17Jan 20, 2025Star
They haven't even posted on their website that Armor is NOT compatible with Windows on ARM, so I doubt it's any priority for them. I think until there are enough ARM based computers that it cuts into their bottom line that they will just ignore the issue.
- darkwing81Jan 20, 2025AspirantThanks! Yeah, it's unfortunate, but not a surprise. I should have just went with a Bitdefender subscription...
- JB_04Jan 20, 2025TutorUnfortunately they closed my support case and couldn't tell me when it was happening.
