-SlowJoe-
Jul 31, 2022Apprentice
Netgear Armor Not Recognizing Bitdefender for Armor on Mobile Devices
Netgear Armor has been really solid for me the last 6-7 months since purchasing my RAXE500. Before I get into the issue, my modem (CM2000), and router (RAXE500) firmware are fully up-to-date. My iOS ...
Jeffgear
Aug 27, 2022Virtuoso
You can try deleting all of the same device entries in the Armor console and then relaunching the Bitdefender app on the device so it’s re detected. Armor will eventually rescan it and may reconcile its entries for that device. For me this removed an extra duplicate device entry but didn’t fix the original issue with Orbi app thinking Bitdefender wasn’t running on the device. I even tried deleting the app from my device, deleting the entries in Armor console, resetting the device’s network settings and re-associating with my wi-fi and starting as if it’s was a new device as far as Bitdefender was concerned - all this did was give me a new MAC and IP for my device but Orbi app still thinks it’s not running Bitdefender. I’d like to be able to flush the Armor settings on the router from a CLI other than just disabling it and then re-enabling in the app, or rebooting which don’t fix the issue. I’m reluctant to spend the day recovering from a factory reset if the backup won’t restore only to find the issue is not resolved. I’ll wait for the next router firmware update or Orbi app update to see if these fix it.
-SlowJoe-
Aug 28, 2022Apprentice
Haven’t fully dived into the armor web-based GUI much, but netgear support reached out and said they were escalating the original post to engineering so hopefully the iOS device protection-recognition issue will be addressed in both the NH and Orbi apps.
- HrpNov 02, 2022TutorWe’ll it’s November now and NETGEAR has not fixed anything yet.
- JeffgearNov 02, 2022VirtuosoFYI I have an open support case now.
I did the nuclear option and factory reset my router and satellites, and deleted the iOS devices from the Armor web console, and removed and reinstalled the Bitdefender app on them. This did not resolve the issue! The only improvement was the security score in Orbi app went from 65 before reset to 90, initially then dropped to 85 once it realised the iOS devices were still eligible after a few days, despite them running full Bitdefender VPN mode.
I then restored the config backup to reinstate my device names and other custom settings given the reset and base configuration didn’t fix the Armor issue. Awaiting update from Support.- KellyOrbiNov 03, 2022Apprentice
Did Netgear Support tell you to do the nuclear option? This is getting ridiculous! We've had this problem since August.
