greddyuk
Nov 19, 2019Aspirant
Netgear Armor
I currently own a RAX120, i have two questions i dont know have to setup:- Question 1: How to a create a separate wifi line? I currently have my main wifi connected to all my security at home. I...
AbhayB
Nov 19, 2019NETGEAR Employee Retired
I currently have my main wifi connected to all my security at home. I want to create a separate SSID line for all NON security appliance. How do i create a separate SSID? is this possible?
I am currently using my "guest" line and i dont think its the correct method.
Question 2:- Im planning to purchase internet security. Does the RAX120 support Netgear Armor? How do you rate the safety of Netgear Armor? is it any good?
Thanks
Hi greddyuk ,
Answer 1: Currently Guest network is the only way to use a seperate SSID for non security appliances. Only limitation is that these devices won't be able to access other devices on the local network if you need. For example, sometimes a lot of apps need your phone and such IOT devices to be on same WiFi network.
Answer 2: RAX120 currently does not support NETGEAR Armor. NETGEAR Armor is powered by Bitdefender's award-winning smart home platform and is ideal for provinding overall cybersecurity for your entire network.
