TDMillard's avatar
TDMillard
Nighthawk RAX200 + Armor; Vulnerabilities detected but shows "You're safe" when I select
Hi all,   I have the RAX200 with Netgear Armor installed and running. This is also installed on my Andriod phone.   Router firmware: v1.0.4.120_1.0.61 (up to date)   On the home screen of the p...
  • Christian_R's avatar
    Christian_R
    Jul 16, 2021
    Hi Anthony,
    Thanks for the screenshot. May you visit armor.netgear.com and see if you're able to view the vulnerabilities there.
    Thanks,
    Christian
