Soulburnxl
Feb 15, 2023Tutor
Re: Orbi router is blocking me from accessing my personal website only?
Same issue. I admin a website and was uploading FTP. After all done, I went back to look at the website and it showed me a blank page. (ERR_CONNECTION_TIMED_OUT). I thought I made a mistake somewher...
- Feb 17, 2023
Thank you, I paid the $50
Netgear Support called me and they resolved it pretty quick. Spoofing the MAC address did the trick.
Router MAC Address > uncheck Use Default Address > Use This MAC Address (ethernet)
Thank you again for responding. I hope this trick will help other people.
CrimpOn
Feb 15, 2023Guru - Experienced User
Soulburnxl wrote:
Did try a factory reset through paperclip and through webadmin > administration > backup settings > erase.
it kept the old SSID info and configurations settings.
Do I read this correctly that a Factory Reset did not rest the WiFi credentials to match the product label ("ORBIxx" and some crazy combination of words) and the admin credentials to "admin" and "password"?
Or, did the router credentials get reset and then you changed them back to match the previous settings?
A perhaps silly question: does FTP access to the web site still work?
Soulburnxl
Feb 15, 2023Tutor
Thank you for responding. Sorry I was unclear.
After the initial reset and a 30-30-30 reset, the Orbi app prompted to connect to ORBIXX, but was unable to connect to ORBIXX.
With the erase function in the WebGUI was able to finally connect to ORBIXX. Went through the ORBI setup, new SSID, and password. Added FTP and HTTPS to blocked services (never) everything else default.
The ORBI app prompts me to activate ARMOR and SMART PARENTAL CONTROLS which I ignore.
Everything seems to work fine, cameras connects, TVs connect, laptops, and phones connect. speed is good.
Open browser, open our website and ...
Little loading circle and then blank page with the error message. FTP not connecting.
Tested other sites and FTP seems to all work just fine.
- CrimpOnFeb 15, 2023Guru - Experienced User
Thanks. Very clear.
I see no reason to put anything in the Block Services page if it is set to Never. Never means "do not enable the Block Services feature."
How about different browsers and different computers?
What the heck was that "testing" with SSH?
- SoulburnxlFeb 16, 2023Tutor
Reading some posts on this forum and Reddit It seems that it might be something with Armor (Bitdefender blocking the website) or SPC but both are stuck behind a paywall. I don't feel we need to pay for a subscription or gearhead subscription to get our website back enabled if we haven't had any other issues with the product. I wish the original poster would respond and let us know if they ever got a solution from Netgear.
- CrimpOnFeb 16, 2023Guru - Experienced User
f Armor and SPC are not enabled, then they are not part of the problem. Yes, they are both paid services (after a "free trial" which is why I have never enabled either one.) Some customers appear to find either or both services worth the cost. People have paid for Windows anti-virus products for decades while Windows Defender is bundled with the system at no cost.
As a customer, I find two aspects of this situation very disappointing:
- The customer has an open case which has not been resolve when that "90 days" expires and Netgear's system claims, "time's up. Time to pay."
- As far as I can tell, Gear Head makes to promise to actually do anything. I rather imagine it would be worth $49.99 to get this crazy episode behind you. (I've spent more than $50 going out to dinner.) But... what happens when they charge your credit card and then ...... (problem not solved)????
Just as a crazy thought, what happens if you attempt to 'ping' the website URL?
(i.e. open a Command window, or run some application that can do ICMP requests [ping])
- SoulburnxlFeb 17, 2023Tutor
- SoulburnxlFeb 17, 2023TutorNot sure where you saw $50 these are the options i see, lowest is $90 for six months.
- CrimpOnFeb 17, 2023Guru - Experienced User
https://www.netgear.com/home/services/gearhead/
I did not find a footnote on the page explaining what the "*" indicates.
- schumakuFeb 17, 2023Guru - Experienced User
Considering 99,95 of the Web and other Internet services require using https - I don't wonder a second when you have massive issues using your Internet.
Why on earth the https service is blocked?
Yes, the big world of the internet is blocked, must be blocked therefore. Wonder where such brilliant ideas are sourced 8-)
Sure, it must be Armor or Bitdefender 8-/
I believe the Original Poster (OP) was attempting to say "Never block https." As I pointed out in post #6, In the context of Service Blocking, "Never" means "Do not enable this feature at any time."
I am stunned that spoofing the router MAC address could have been the solution, because it worked before."
