Soulburnxl
Feb 15, 2023Tutor
Re: Orbi router is blocking me from accessing my personal website only?
Same issue. I admin a website and was uploading FTP. After all done, I went back to look at the website and it showed me a blank page. (ERR_CONNECTION_TIMED_OUT). I thought I made a mistake somewher...
- Feb 17, 2023
Thank you, I paid the $50
Netgear Support called me and they resolved it pretty quick. Spoofing the MAC address did the trick.
Router MAC Address > uncheck Use Default Address > Use This MAC Address (ethernet)
Thank you again for responding. I hope this trick will help other people.
CrimpOn
Feb 15, 2023Guru - Experienced User
Soulburnxl wrote:
Added FTP and HTTPS to blocked services (never) everything else default.
Little loading circle and then blank page with the error message. FTP not connecting.
Tested other sites and FTP seems to all work just fine.
Thanks. Very clear.
I see no reason to put anything in the Block Services page if it is set to Never. Never means "do not enable the Block Services feature."
How about different browsers and different computers?
What the heck was that "testing" with SSH?
Soulburnxl
Feb 16, 2023Tutor
Reading some posts on this forum and Reddit It seems that it might be something with Armor (Bitdefender blocking the website) or SPC but both are stuck behind a paywall. I don't feel we need to pay for a subscription or gearhead subscription to get our website back enabled if we haven't had any other issues with the product. I wish the original poster would respond and let us know if they ever got a solution from Netgear.
