captinboondoggl
Mar 18, 2020Guide
R7900P Armor?
When I login to my router (web or all) the "armor" solution is displayed prominently but its unable to be activated. The support page does not list this router as being supported. Is support coming...
- Mar 24, 2020
Hello captinboondoggl,
May you let us know if you're able to enable/disable remote management? May you also try reinstalling the Nighthawk app to see if there are any improvements.
Thanks,
Christian
captinboondoggl
Mar 23, 2020Guide
Thanks for the reply unfortunately this does not work - I get an error - device is offline. I have the latest firmware and nighthawk app.
AbhayB
Mar 23, 2020NETGEAR Employee Retired
AAh okay. Sorry for the trouble.
That's more technical issues it seems. Let me have a support person reach out to get data such as your serial number etc.
- captinboondogglMar 23, 2020Guideit Looks like it should work and I keep getting emails telling me to try it out but so far I get that error message whenever I click on “security “ from the app.
- Christian_RMar 24, 2020NETGEAR Employee Retired
Thanks,
Christian
- captinboondogglMar 24, 2020Guide
enabling then disabling remote management as suggested seems to work. when I click on security I now get the option to enable armor. I then activated my trial successfully
THanks for this workaround - you might want to add it to the Knowledge base article about how to enable armor.
Happy to hear! Have a wonderful day and take care!
Christian
