John_Ba
Nov 02, 2021Luminary
Renewal
My existing sub runs out early December, it’s not at all clear how to renew it. No link in my Netgear account, in app or web Orbi page. Also if I renew early is the time added to the existing time ...
Nov 03, 2021Guru - Experienced User
You should see a possible nofication in the Orbi app on when you select the Armor tile. Should be some information there. There maybe a MY Subscription listed on the left side of the app if you select the upper top left icon then down the left side menu...
John_Ba
Nov 03, 2021Luminary
Thanks under the dropdown menu with settings at the top and ending with reboot is my subscriptions, which has Armor Security telling my it expires December 05 but nothing about renewal. I have been using PC's for over 30 years and had many diffrent security programs in that time, non have been so difficult to deal with as this!
- FURRYe38Nov 04, 2021Guru - Experienced User
Well you still have time and it may not show anything until it gets closer to the expiration date.
Contact a forum moderator to see if they can help out.
- John_BaNov 04, 2021Luminary
Thanks how done so.
- John_BaNov 05, 2021Luminary
Well no idea if result of e-mail, never had a reply, but a 50% off offer was shown in the Orbi app. Used that to renew, lost a month but went through OK. BUT in my subcriptions I am told
Contract Auto Renewal
These products and all other items currently set to auto-renewal will now use and store the payment method selected for this order.Auto Renewals can be cancelled anytime by clicking the "Turn Off", button below.
There is no option to turn it off.
In over 30 years I have not found such a poor firm to deal with how apart from blocking recurring payments do you do it?
