AidanS
Oct 21, 2022Aspirant
Security warnings from LG tv connected to RBR850
I have recently begun to get multiple security warnings from my Netgear Armour software about my tv - a LG C2. The tv is connected by ethernet cable to my RBR850 router. Has anyone else experienced t...
- Mar 02, 2023
I have just downloaded the latest version of the LG software (03.30.45) and this seems to have resolved the issue.
Jeffgear
Dec 03, 2022Virtuoso
How old is the G2 model and is it on the latest firmware?
JCvanDoorn
Dec 05, 2022Aspirant
It's a couple of months old and all software is up-to-date.
- JeffgearDec 05, 2022Virtuoso
You could send the scan results to LG Support. They may appreciate the heads up and issue an update with fixes, assuming it's still being reported as vulnerable by Armor.
- CrimpOnDec 16, 2022Guru - Experienced User
Is there a method to tell Armor not to scan that device?
- JeffgearDec 17, 2022Virtuoso
I'm not aware of any options to disable the Armor scan but this sounds like a good feature request along with the option to exclude devices from being eligible for Armor Security I.e. for devices it thinks are eligible but are not, or work devices that you have no rights to install your own apps onto.
