wchp
Apr 22, 2019Luminary
Stateful or Deep packet inspection or other?
Does the Bitdefender/Netgear Armor firewall use SPI (Stateful packet inspection, e.g. SonicWall) or DPI (Deep packet inspection, e.g. Bitdefender Box 2) or is it just a blacklist of know bad sites an...
Orbi-Roc
Jun 15, 2019Luminary
Thank you wchp for the prompt response. How were you able to ascertain that if I may ask?
You know, I disabled Armor because I wasn't happy with Bitdefender mediocre (at best) support; and had too many issues on both Windows PC's and Mac's. But I also had issues with Ultra HD streaming on Netflix -- the video would skip here and there throughout a viewing session. But none of these issues, albeit annoying, were/are deal-breakers IF the filtering at the router level is adequate. So this puts my pursuit of this issue somewhat in context.
Again, thanks for your help. I believe that your posts have been very helpful, not only for folks like me who are still on the sideline, but for the Community at large.
wchp
I called sales and asked pre sales support who then had to find a sales engineer who then hand to get support involved...
Finally got to someone who understood exactly what my question was and was able to discuss throughput overhead and potential for latency and jitter.
I have only been able to measure about a 7-10% hit on throughput, no real change in latency or jitter.
I will admit the AV client installation leaves a bit to be desired.
Key there was to make sure ALL AV products from any other vendor were uninstalled and on Windows machines defender was turned off before you ran the install.
On the MACs a nusience to have to go into security and manually grant disk access to the bitdefender daemon.
I install SonicWall and Untangle firewalls for customers. I have found so far that the Armor product seems far better suited to a typical homeowner but that the BD-AV desktop software install still seems a little cumbersome.
I have experienced no issues with any streaming (Roku, Amazon and Apple TV) on any of the client devices.
I am running this on a RBR-50. I did not test it on a RBR-20.
