tron00100
Feb 14, 2019Aspirant
Readynas nv+ / READY NAS DUO
Hello
I use a READNAS Duo x2 RDN2110 and also a ReadyNAS NV+
The question I have.
what kind of Hard drive I can use for both devices,
Can I use any Hard drive, or is there a requireme...
- Feb 17, 2019
Hi Mike
Welcome to the Community!
First off you may want to make sure what version of Duo and NV+ you have. You can check that through this article though the easiest way to check is on the FW being used, v1s should be on OS 4.x while v2s are on OS 5.x
This is to make sure you will be using the correct disks available for your unit. Duo V1 and NV+ V1 have a maximum of 2TB drives per bay while V2s have 4TB maximum compatible drives and any NAS purposed drives is advisable.
Hope this helps!
Regards
