Rickp703
Oct 25, 2022Aspirant
Reboots on Thursdays
I have a RBRE950 which is doing the same thing... Reboots on Thursdays - every Thursday about 2PM (but sometime in the afternoon) (just got done with another round on a Tuesday)
Oct 25, 2022Guru - Experienced User
Does this happen with just the RBR lone online and the RBS turned OFF?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- Rickp703Oct 25, 2022Aspirant
Thanks for the note... All 5 Orbis (Router + 4 Satelites)are humming along just fine, and the router loses connection, flashes White and them all devices (including all satelites) lose connection (and also flash white)... I have Frontier Fiber as ISP with 1 GBps throughput. When I look at neighbors, I only have (1) network that shows up via my Iphone 14.
As for the Modem, It states that it is a "MGS-PON Ont"
Model: FOX222
The markings on the device only refer to Frontier... however my Google searches have lead to suggesting that this is a (CIG - Cambridge Industries Group) product.
I do have a Cat6 flat cable (more than happy to do a Cat 6a), however the regularity leads me to feel as if something is setup to restart on a (pseudo) schedule - How can 6.9 days of the week be flawless, and then randomly (not so randomly) can this happen ?
And - why hasn't Netgear released Firmware updates for the RBRE950, but they do so for the RBRE960?
- FURRYe38Oct 25, 2022Guru - Experienced User
Do you have Armor enabled or had Armor enabled at all?
The 950 and 960 series are both at the same FW level and seem to use same versioning.
We don't get information on when new FW comes out. Mfrs don't make that known. Just have to keep an eye on there download page or here in the forums.
