Rickp703
Oct 25, 2022Aspirant
Reboots on Thursdays
I have a RBRE950 which is doing the same thing... Reboots on Thursdays - every Thursday about 2PM (but sometime in the afternoon) (just got done with another round on a Tuesday)
Oct 25, 2022Guru - Experienced User
Yes please disable Armor using the Orbi app. After its been disabled thru the orbi app. Power OFF the RBR for 30 seconds then back ON.
Rickp703
Oct 28, 2022Aspirant
FURRYe38 - Turned Armor off - No Thursday reboots... I'm going to leave it off to see how long we go without a reboot... Perhaps the Armor software is trying to refresh & crashing ?? There is a lot of crosstalk on these topics... I will circle back to see if this stops the problem & how to address the loss of Armor (if that seems to become the root problem)
- FURRYe38Oct 28, 2022Guru - Experienced User
No idea what Armor is doing. Not the first time Armor has been a culprit is causing problems.
Only other item would be to factory reset and setup from scratch with out Armor being enabled. If not reboot, re-enabled Armor then test to see if reboots return.
- Rickp703Nov 07, 2022Aspirant
FURRYe38 Over 11 days, no reboots!!! I dare say that Armor is the culprit - Will keep it off for a bit longer, turn it back on & wait for the crashes to happen. How does a service you pay for wreck the system? I'm sure there is some kind of armor update happening ?
Does this mean my use of this service is dead ?
