Rickp703
Oct 25, 2022Aspirant
Reboots on Thursdays
I have a RBRE950 which is doing the same thing... Reboots on Thursdays - every Thursday about 2PM (but sometime in the afternoon) (just got done with another round on a Tuesday)
Oct 28, 2022Guru - Experienced User
No idea what Armor is doing. Not the first time Armor has been a culprit is causing problems.
Only other item would be to factory reset and setup from scratch with out Armor being enabled. If not reboot, re-enabled Armor then test to see if reboots return.
Rickp703
Nov 07, 2022Aspirant
FURRYe38 Over 11 days, no reboots!!! I dare say that Armor is the culprit - Will keep it off for a bit longer, turn it back on & wait for the crashes to happen. How does a service you pay for wreck the system? I'm sure there is some kind of armor update happening ?
Does this mean my use of this service is dead ?
