Cassey1
Nov 13, 2020Follower
Reinstall Bitdefender Antivirus software on my Mac Pc
I upgraded my operating system on my Mac Pc to (MacOS Big Sur) , and Bitdenfender was not working anymore, not activated. The support site told me to go login my Netgear account and select my device...
Retired_5902
Nov 14, 2020Initiate
Same issue. Nothing on NetGear site. Big Sur has been in Beta for quite the while. Would think subscribers would be made aware of issues in advance, or refunds provided for lack of service..
Retired_5902
Nov 24, 2020Initiate
First, follow the instructions at
https://www.bitdefender.com/consumer/support/answer/1446/
Then, find the Netgear folder in /Library. I renamed that, in case I needed it back. and rebooted.
The Netgear Armor install of BitDefender worked after that. I deleted the renamed folder, because the install routine created a new Netgear folder in /Library.
