mishikal
Aug 26, 2021Tutor
Remove AppArmor popup
I have no interest in AppArmor, but every time I log into my router an annoying popup occurs to try and get me to activate it. Is there some way to permanently disable this ad spam?
- Aug 27, 2021
Select the do not show again link at the bottom of the popup window.
Aug 27, 2021Guru - Experienced User
mishikal
Sep 01, 2021Tutor
Oddly that option was "greyed" out, which generally indicates it's a link one has visited before, which is why I missed it. Not sure if that's done deliberately or not.
