runandwritebq
Jul 30, 2024Aspirant
Scan with Netgear Armor not working
I like to scan anything I download, and I usually do so by right clicking on the item in my folder, selecting "Netgear Armor" and then selecting "Scan with Netgear Armor," but yesterday that stopped ...
- Nov 01, 2024
FOUND WORKAROUND solution.In case anyone else encounters this problem, solution below:
It works when activated from the "old-windows layout" right click menu accessible via right click>more options
So the netgear armour functions per file/folder can be activated by:
>Right click file
>more options (bottom option in the rightclick menu)
>netgear
>NA scan or shredder
Aug 06, 2024Guru - Experienced User
Try restarting the PC?
runandwritebq
Aug 06, 2024Aspirant
I tried that before posting here. I had even tried uninstalling and reinstalling, and nothing. Now it seems to work sometimes. A couple of days ago it worked, today it doesn't again.
- FURRYe38Aug 13, 2024Guru - Experienced User
Might contact Armor support about this.
- inekeOct 31, 2024Aspirant
did you solve this. I have the exact same problem.
- FURRYe38Oct 31, 2024Guru - Experienced User
- inekeNov 01, 2024Aspirant
>Right click file
>netgear
>NA scan or shredder
