aquasaif
Mar 14, 2023Aspirant
"Security" Option Not available in Nighthawk App - Router Nighthawk MR60
I have purchased Netgear Armor subscription, but there is no 'Security' option in my Nighthawk app of android phone. Following are the details. Can someone help please? Hardware Version M...
Mar 14, 2023Guru - Experienced User
did you update the app?
Or uninstall/reinstall the app?
aquasaif
Mar 15, 2023Aspirant
Hi,
Thanks for your reply. Yes, the app is latest version from Google Appstore. I did uninstall and reinstall the app also. But no change.
I also downgraded the router (& satellite) firmware versions to previous 2 versions. But still didn't solve the problem.
Looking forward to get some guidance from you or the community.
Thanks
- plemansMar 15, 2023Guru - Experienced User
You could always try a factory reset on the router.
