Wulff
Dec 09, 2020Aspirant
Security vulnerability in Orbi RBR20?
Recently bought a RBR20 with one month Netgear Armor activated. Today I received messages from my Synology NAS that it blokked the RBR20 ipaddres because of to many wrong logon attempts. It seems N...
- Dec 13, 2020
found the easy solution, well hidden:
Christian_R
Dec 09, 2020NETGEAR Employee Retired
Hi Wulff,
May you check to see if your RBR20 is on the latest firmware. I would also recommend disabling Armor to see if you're still receiving the messages.
Christian
- WulffDec 10, 2020Aspirant
Thanks Christian, Yes the router is at the latest level, automatically updated at install.
There is no option where I can influence any setting in Armor (at least I can't find one) so disabling would be difficult.
I will search in the forum if this is possible but I think not.
Looking for ways to logon via telnet, enable telnet via http://192.168.0.1/debug.htm
then finding the right pid to kill bitdefender is not easy, which pid do I have to kill?
- WulffDec 13, 2020Aspirant
