Wulff
Dec 09, 2020Aspirant
Security vulnerability in Orbi RBR20?
Recently bought a RBR20 with one month Netgear Armor activated. Today I received messages from my Synology NAS that it blokked the RBR20 ipaddres because of to many wrong logon attempts. It seems N...
- Dec 13, 2020
found the easy solution, well hidden:
Christian_R
Dec 09, 2020NETGEAR Employee Retired
Hi Wulff,
May you check to see if your RBR20 is on the latest firmware. I would also recommend disabling Armor to see if you're still receiving the messages.
Christian
Wulff
Dec 10, 2020Aspirant
Thanks Christian, Yes the router is at the latest level, automatically updated at install.
There is no option where I can influence any setting in Armor (at least I can't find one) so disabling would be difficult.
I will search in the forum if this is possible but I think not.
- WulffDec 10, 2020Aspirant
Looking for ways to logon via telnet, enable telnet via http://192.168.0.1/debug.htm
then finding the right pid to kill bitdefender is not easy, which pid do I have to kill?
- WulffDec 13, 2020Aspirant
