AidanS
Oct 21, 2022Aspirant
Security warnings from LG tv connected to RBR850
I have recently begun to get multiple security warnings from my Netgear Armour software about my tv - a LG C2. The tv is connected by ethernet cable to my RBR850 router. Has anyone else experienced t...
- Mar 02, 2023
I have just downloaded the latest version of the LG software (03.30.45) and this seems to have resolved the issue.
Jeffgear
Feb 20, 2023Virtuoso
You could log a ticket direct with Bitdefender Support here:
https://www.bitdefender.com/consumer/support/
Scroll to the bottom and click contact Bitdefender Support then:
1. How to's & Troubleshooting Bitdefender product
2. Type of issue:
Troubleshooting
3. Which product do you need help with?
NETGEAR Armor powered by Bitdefender
Then choose email…
Good luck!
2. Type of issue:
Troubleshooting
Then choose email…
Good luck!
AidanS
Mar 02, 2023Aspirant
- MontereyFredMar 07, 2023Star
I downloaded a similar LG update and subsequently received a security warning with identification of 341 vulnerabilities. Perhaps a false positive, perhaps sloppy work and/or inattention to detail in LG's webOS. The TV stays on our guest network at least until that answer is known. We use Roku devices anyway, and it doesn't bother us to leave our "smart" TV "dumb."
In any case, I don't believe this matter is closed...
