DAVID533
Jan 02, 2019Aspirant
Setup USB Device in ReadyNas NV+
I connected a USB Flash Drive to the NV+ to test out the USB connection. I did not setup any password to access the USB flash drive. I can see the USB drive in my network, but when I try to open it w...
- Jan 09, 2019
Hi DAVID533
Welcome to the Community!
if it is asking for your Windows Administrator Password instead of the NAS then there might be settings on your Windows OS that implement this request. Have you setup or installed any security app?
What you can set on the NV+ would be the permission for your data but it should not ask for the password if you have not set any.
By default the Admin account will have access. Have you tried inserting the USB Disk on the PC itself and see if it still ask?
Here's an article that may help on this issue.
Windows requires Administrative rights
Hope this helps!
Regards
Marc_V
Jan 09, 2019NETGEAR Employee Retired
Hi DAVID533
Hope this helps!
Regards
DAVID533
Jan 09, 2019Aspirant
Thank you very much, Marc_V. My problem is solved.
