Christian_R
Feb 18, 2020NETGEAR Employee Retired
Share Your NETGEAR Armor Experience
Hello NETGEAR Armor Community!
Thank you to all who have activated your NETGEAR Armor trial and to those who have subscribed to our cyber security service. Since the launch of the service we h...
rinthos
Aug 02, 2020Luminary
1: If armor is serving a purpose for you and you are getting value out of it, keep it. If not, drop it.
2: Armor expiring should not prevent you from connecting to WiFi. If you are worried that is the case, turn it off before it expires or buy a subscription. But I can attest that with some devices with it enabled and others without it (I have multiple remote sites w/ netgear routers) I have never had that type of problem.
3: you can always turn it off or back on if you have a live subscription or trial period...
https://kb.netgear.com/000060900/How-do-I-turn-NETGEAR-Armor-on-or-off-using-the-Nighthawk-or-Orbi-app
Regarding performance there is a slight latency hit but for general throughput for a higher end router (such as Orbi) you are unlikely to notice it. The first time you connect to a remote website or server the initial connection time is milliseconds slower, but that's about it.
Plus you get the free bit defender software which with the web browser plug in may be more impactful to performance...again that depends on your PC or Mac specs...
Use your trial period to push it to the limits. If you have been happy so far my guess is you shouldn't worry about performance. You are likely to figure it out after just a few days of performance testing.
Hope this helps.
Hope this helps.
Mikener
Aug 03, 2020Aspirant
Thanks. That help's a lot.
- blenderpilotNov 25, 2020Tutorhttps://community.netgear.com/t5/Nighthawk-WiFi-Routers/Nighthawk-R7000P-printing/m-p/2004685/highlight/true#M173746
A bit dissappointing really.
