Christian_R
Feb 18, 2020NETGEAR Employee Retired
Share Your NETGEAR Armor Experience
Hello NETGEAR Armor Community!
Thank you to all who have activated your NETGEAR Armor trial and to those who have subscribed to our cyber security service. Since the launch of the service we h...
genglehardt
Feb 19, 2021Aspirant
Since purchasing R7000P with Armor (prior R7000 did not have Armor) all my printers print out a single nonsensical 3 or 4 line heading on four separate pieces of paper about once per week.
HEAD / HPPT/1.1
Host: 192.168.1.5:9100
User-Agent: curl/7.59.0
Accept: */*
Is an example of one of the print-outs. With 4 printers this is a signficant waste of paper. Please find a way to eliminate this paper waste.
Gary
- BruKatJun 02, 2021Aspirant
I had same issues and this was my fix
The page you are seeing is being generated by Netgear Armor weekly scans.
The Netgear Armor / Bit Defender team will need to update their scanner. It appears currently they are sending scan commands to your printer to try to "hack it", but some of those commands are being sent over ports that are interpreted as "print" commands.
If your printer allows you to block IP addresses from printing, you could likely block any printing from 192.168.1.1. IF it doesn’t, then either it will need to be Off when the Armor scan occurs, or there will need to be an update to the Armor Scanner.
I know Netgear often updates the Bitdefender Armor scanner in newer firmware...so make sure you are on the latest firmware for your router, as it may contain this fix. If not, I'd open a case w/ Netgear and even Bit Defender, they'll need to have their teams provide an update.
Hope it helps
