olfin7
Oct 11, 2024Aspirant
Suspicious Connection attack warning on device from the IP address that is that device
Hi. We have a home network with Netgear Orbi wifi routers, protected by Netgear Armor. Recently we've been getting lots of "Attack Found on "computername"" messages. In the details it says "Suspicous...
Oct 16, 2024Guru - Experienced User
What Orbi model system do you have?
What FW version is loaded on the system?
What is the brand and model# of the device at 10.0.0.20?
olfin7
Oct 19, 2024Aspirant
I had the RBR50 and satellite with the latest firmware. However, I noticed at the time that the firmware was no longer being updated and was like two years old. Since then as part of my trying to make sure everything is fully secured regardless of if it was a real threat or not, I've purchased a new Orbi and updated the firmware to the very latest on it.
This notice was happening to two different devices. One was a MacBook Pro (older Intel version) and the other was a PC running Windows 11.
The modem is a Telus Arcadyan nh20a. I also realized that it was not running in bridge mode, not sure if that could've caused false warnings. I've since fixed it to run in bridge mode.
- FURRYe38Oct 21, 2024Guru - Experienced User
This should be last official FW update for your 50 series Orbi system:
- olfin7Oct 21, 2024AspirantYes, that’s the one I had. A year and a half old. But the device is also listed as officially no longer supported.
- FURRYe38Oct 22, 2024Guru - Experienced User
Correct.
For the 50 series if you want continued FW support beyond NG, Voxel's FW it kept up to date and seems to be working for most who try it. Something to check over on the SmallNetBuilders forum for more information is where he hangs out at.
