GatorMitch
May 20, 2020Aspirant
Trying Armor trial, will it work with my current norton
I'm using Armor trial but have not installed Bitdefender on my clients which include pc's, android streaming boxes, iPhones, iPads. I have a norton anti-virus on all my pc's. I understand the Armor works on the router level, but was wondering if the Bitdefender would conflict with the Norton running on my pc's. I have subscription to norton that is good for another 8 months so I don't want to subscribe to Armor if I can't use Bitdefender with my norton antivirus. Can anyone tell me how this would work?
- Christian_RNETGEAR Employee Retired
Hello GatorMitch,
You should not experience any issues with Norton and NETGEAR Armor running simultaneously.
Christian
- GatorMitchAspirant
Thanks. How about if I add bitdefender on the same devices running norton. My PCs currently use norton anti virus. Will I have problems if I install bitdefender on the same PCs currently running norton?
Hi GatorMitch,
That should not be an issue. I would also recommend checking in with Norton to see if they have any additional info.
Christian
