DaveAU
Aug 20, 2022Tutor
Trying to reactivate expired Armor on RBR50. Cannot due to "This plan is not available".
Hi, I've had my RBR50 for some time and wanted to subscribe to Armor. When I follow the directions on Netgear's site I get an error reporting "This plan is not available". I've power cycled, che...
- Aug 24, 2022
Hello DaveAU,
Welcome to the NETGEAR Community!
I understand that you are not able to renew your Armor plan due to your desired plan not being available.
Please PM the following information so I can endorse you to our support team:
Name:
Email:
Phone Number:
Device Model:
Firmware:
Serial Number:
Preferred time to be contacted:
App version:
Please provide this information as soon as possible!
I look forward to hearing from you!
Best,
Kevin
Community Team
Aug 22, 2022Guru - Experienced User
What firmware is on the router? (and the satellites)
DaveAU
Aug 22, 2022Tutor
V2.7.3.22 on both.
- plemansAug 22, 2022Guru - Experienced User
Theres a newer 2.7.4.24
Have you tried manually updating to that and activating?
- DaveAUAug 22, 2022Tutor
I've checked for updates with the Orbi app which didn't find an update. I've manually updated the router and satellite to 2.7.4.24.
I am still getting the same error with Armor. - plemansAug 22, 2022Guru - Experienced User
Have you tried contacting support to purchase armor and activate it?
https://www.netgear.com/support/product/netgear-armor.aspx
You could also just try a factory reset. Its kind of a default answer but surprisingly works
Sadly the support process points everyone here. I've sent an email asking for assistance.
It really shouldn't be this hard to give a company money.
