Borling's avatar
Borling
Unabel to apply SqueezeCenter
Hi,
I hope someone out there can help me - I am not a technical guy at all, so pls keep any replies simple.
I have a Squeezebox duet and a ReadyNAS Duo. This have worked fine for many years. Unfortunately my (one and only) harddrive "broke", so I had to buy a new. I have tried to install that, and copied the backup of my music over to the new harddisk.
I use the RAIDar 4.1.16 and the Logitech Media Server 7.9.0.
I can see my harddisk from the RAIDar and from my Windows path finder. I can acces the harddisk from the Windows path finder and see all the music. The Logitech Medea Server also tells me that there are 8.731 tracks.
I have tried a lot, but are unable to apply the SqueezeCenter under Streaming Services when I use the RAIDar
What do I need to do ? I have tried a lot during the last 3 weeks - but not succes
Thanks
Ole
    • Borling's avatar
      Borling
      Hi,
      Thanks for your reply - unfortunately I can't open the link - but it doesn't matter, as I this weekend bought a Bluesound Node 2, which works perfectly
