wvwavere
May 17, 2023Initiate
Unable to activate Netgear armor
I recently purchased a Orbi 852 set with Armor and Parental control subscriptions. Activating parental control worked without any issues, but when I attempt to activate Armor from the android app it...
- May 22, 2023
Installed a beta firmware version provided by support and another factory reset and the issue is now resolved.
Blanca_O
May 18, 2023NETGEAR Employee Retired
Hi wvwavere
System shows that your case is already escalated to the next level of support team. We have notified support to follow up on your case and they should be contacting you as soon as possible to discuss the next action.
Blanca
Community Team
