wvwavere
May 17, 2023Initiate
Unable to activate Netgear armor
I recently purchased a Orbi 852 set with Armor and Parental control subscriptions. Activating parental control worked without any issues, but when I attempt to activate Armor from the android app it...
- May 22, 2023
Installed a beta firmware version provided by support and another factory reset and the issue is now resolved.
wvwavere
May 22, 2023Initiate
May 23, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
