javidelgadillo
Mar 10, 2021Tutor
Unable to unblock URL
Starting this week, the Armor Security started blocking http://links.a.signalkit.com/ls/click which my son's school uses to send us flyers. I went to the app on Android to try and unblock it, but I ...
CFoulon
Jul 14, 2021Guide
I have been trying to unblock this and other sites with the .live domain, and I get this generic error.
blitz619
Aug 25, 2021Guide
Disable NETGEAR Armor and get yourself decent VPN app such as NordVPN and be done with Netgear Armor.
- CFoulonAug 25, 2021Guide
I dont see an to disable it on the router interface or admin settings.
- blitz619Aug 25, 2021Guide
I disabled it on my phone app, I couldnt find it in the web interface on my pc. I have an Orbi routerso I have the Oribi app. When you open the app there is a Home button top left of the app, then go to Settings, then Security, there will be a radio button you can toggle on or off. In a few seconds your router through the web interface on your pc or laptop will refresh. Hope this helps.
I have the NightHawk, and ended up finding a similar setting in the mobile menu. Seems strange to just have something in the mobile app and not on the device configuration page.
