wolgar's avatar
wolgar
Follower
Sep 28, 2021
Unknown device joining network "generic streaming device"
I had a "generic streaming device" join my network with a MAC of 9E:10:AC:98:4C:11 which lookup tools are saying is not belonging to any vendor. I can't find the device in the device list. Any ideas what that could be?
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi wolgar
    Welcome to NETGEAR Community!
    Kindly access the router Web UI, go to Attached Device and check if the device-in-question is listed.
    Please provide the firmware version of the Orbi router and Orbi Satellite.
    Have you tried to turn off and on the router then check if it will make any difference?
    Blanca
    Community Team
  • Hi,
     I'm having the same problem, what did you end up doing to remove this generic device?
