user356
Nov 09, 2019Guide
Unwanted printing
I get 3 pages printed each week. HP 5200 wireless printer did NOT print this out when connected to previous ASUS wifi router. Problem started with installation of ORBI RB50. How do I stop this usel...
CrimpOn
Nov 09, 2019Guru - Experienced User
Once each week. Fascinating.
Just wondering, what is the IP address of this HP printer?
If it is not 192.168.1.7, then what is at that IP address?
Thanks
Blanca_O
Nov 10, 2019NETGEAR Employee Retired
- user356Nov 10, 2019Guide
yes, security activated
- CrimpOnNov 10, 2019Guru - Experienced User
Troubleshooting something that happens once every seven days can be a challenge. What I would do is set up a LAN/WAN capture to begin shortly before the next occurance. After the three pages print, stop the capture, save the debug file, and open it in Wireshark (or equivalent). Filter packets by the IP address, and that should reveal which device on the network is doing the printing.
I do this so often, it is not particularly complicated. If this sort of thing appears complicated (because it is), maybe turn the priniter off for an hour each week?
