user356
Nov 09, 2019Guide
Unwanted printing
I get 3 pages printed each week. HP 5200 wireless printer did NOT print this out when connected to previous ASUS wifi router. Problem started with installation of ORBI RB50. How do I stop this usel...
User_JJ
Nov 20, 2019Aspirant
Have experienced the same unwanted printing. Did not even eject the page from my Epson ET-2650.
I have RBR50 with Netgear Armor (Bitdefender) activated. I would think a better solution exists or fix for Armor than simply deactivating it as some have. This has occured twice so far the last several weeks. Did not have this problem before.
Printed without ejecting the paper:
HEAD / HTTP/1.1
HOST: <my ip of my printer>:9100
User Agent: curl/7.59.0
Accept: */*
OPTIONS * RTSP/1.0
CSeq: 1
User-Agent: curl/7.59.0
GET / HTTP/1.1
Host:<my ip>:9100
Nov 21, 2019Guru - Experienced User
Also as a suggested work around until Armor is fixed, use other alternative means to connect to the printer. USB or Ethernet maybe available on these printers.
Please continue to post over in the Armor forums.
Thank you.
