user356
Nov 09, 2019Guide
Unwanted printing
I get 3 pages printed each week. HP 5200 wireless printer did NOT print this out when connected to previous ASUS wifi router. Problem started with installation of ORBI RB50. How do I stop this usel...
CrimpOn
Nov 20, 2019Guru - Experienced User
I think we all would agree that the preferred solution is for Netgear to "fix the software". Until they do, however, there appear to be two solutions: (a) waste some paper once a week, or (b) deactivate Armor.
There is probably a lot more discussion on this topic over on the Armor forum: https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor I did not activate Armor, so I do not regularly look at that forum.
srs51
May 29, 2020Aspirant
I just posted this, and very soon after found the "UNWANTED PRINTING" topic
I installed my Orbi RBR20 system late last year, and generally like it. No issues, but since moving to the ORBI with 2 satelites there have been multiple ocassions where both of the printers in my network print three single-page copies as follows:
HEAD / HTTP/1.1
Host: 192.168.1.12:9100
User-Agent: curl/7.59.0
Accept: */*
The remainder of each page is blank. The two printers are:
1, an HP laserjet connected to an ORBI satelite using its RJ-45 port and Cat 6 cable; and
2. a Canon MCF color laser printer connected to the Base Station using its RJ-45 port and Cat 6 cable
This never happened until after I started using the ORBI components. I used an Apple Airport Extreme previously.
Has anyone else had a similar experience? If yes, were you able to stop it from happening? Thanks, Steven
At least I am not imagining it! Has anyone figured out what to do other than ask Netgear to address it? Thanks, Steven
- larryindublinMay 29, 2020Luminary
All I can say is that I had this issue with my Orbi RBK53 (1 Router, 2 Sat) setup and HP color laserjet but it went away after a printer firmware upgrade. Also running latest version on the Orbi system.
- user356May 29, 2020Guide
Same here, as last responder. HP- Orbi 53, print pages as you describe. Solutions are uninstall armor and use your own virus protection. And is seems it eventrually (months) goes away. Do your armor, orbi and hp updates first and see if that just fixes it in a week or two. Mine printer out every Saturday. If no joy dump the Armor.
