user356
Nov 09, 2019Guide
Unwanted printing
I get 3 pages printed each week. HP 5200 wireless printer did NOT print this out when connected to previous ASUS wifi router. Problem started with installation of ORBI RB50. How do I stop this usel...
Carlosam
Jun 16, 2020Aspirant
I have two new wireless HP printers, OJ7740 and LJ148. Since installed Orbi (security activated), I get 3 pages printed per unit every day. Total waste of paper. Any fix?
larryindublin
Jun 16, 2020Luminary
I had the problem for months with my HP Color Laserjet. It resolved after a printer firmware upgrade and also I am running my RBK53 set on latest 2.5.1.16... Printer is still on wifi and still running armor.
- Mikey94025Jun 16, 2020Hero
While Netgear searches for a way to make the Armor security scan not trigger unwanted prints from networked printers, those of you with HP printers may be able to disable Web Services to stop the prints (I do not use Armor and have not verified this solution):
- Instructions are here: https://support.hp.com/in-en/document/c04808536
- HP community thread that refers to this technique: https://h30434.www3.hp.com/t5/Inkjet-Printing/Unrequested-prints-almost-every-night/m-p/7311612#M830643
The HP Web Services feature allows you to email yourself or use Google Cloud Printing on your HP printer. If you don't use these features then you can safely turn it off and see if this resolves your unwanted prints.
Sorry, I didn't get the first link right...
